O2 Sensors
Old Dec 23, 2009 | 10:00 AM
Kensai's Avatar
Kensai
Default O2 Sensors
Okay, I decided to change out my back O2 sensor, I got the replacement part. The question is, how hard is it to gain access to the rear O2 sensor? I assume it is on the output side of the cat? Also, this is for my R/T model which has the skid plate underneath so I am not sure if this needs to come off to gain access to th O2 sensors.
Old Dec 23, 2009 | 12:36 PM
Dans01Durango's Avatar
Dans01Durango
I'm 95% sure the rear 02 sensor is behind the cat. IIRC, from my SLT, the skid plate doesn't cover the exhaust so the plate doesn't need to be removed. HTH.
Old Dec 23, 2009 | 01:48 PM
hydrashocker's Avatar
hydrashocker
Mine is pretty much right there underneath, sideways wire on the drivers side (mounted horizontal).
Old Dec 23, 2009 | 03:29 PM
Duranged408's Avatar
Duranged408
Tight area, a o2 sensor socket is 100% recomended, hot/warm exhaust assists
Old Dec 23, 2009 | 05:19 PM
Kensai's Avatar
Kensai
I went and looked under and see the cat. I kinda can barely see the front O2, but cannot find the back O2.
Old Dec 23, 2009 | 10:10 PM
hydrashocker
It should be right there?
Old Dec 23, 2009 | 10:47 PM
IndyDurango's Avatar
IndyDurango
Rear O2 is closer to the muffler than the CAT. From the rear doors... find the center of the exhaust from there. Rear O2 should be right about there and should be fairly easy to access in comparison to the front one.
IndyD
Old Dec 24, 2009 | 01:17 AM
Kensai's Avatar
Kensai
Wow, that is quite a ways back then! Damn, wished I knew this much earlier today after fixing my seat. Cold weather is upon us in DFW the next few days so I am outta luck until we warm up again.
Old Dec 24, 2009 | 08:06 AM
Dans01Durango
40s -50s cold??? Come on! That's great working weather! LOL!
Old Dec 24, 2009 | 10:09 AM
hydrashocker
I second that!
I'm in the mid 20's for a hi and singles an night.........COLD!
