steering column noise
Old Jan 3, 2010 | 12:06 PM
mb98d's Avatar
mb98d
Default steering column noise
after i replaced my heater core i started to notice a few noises that i didnt have before. when i turn the steering wheel i get a clicking noise' but it goes away if i tilt the wheel all the way up. which i find to be strange since the angle on the shaft is greater. i also have a clunking noise that i feel in the wheel if i hit the brakes hard, accellerate hard or hit potholes hard. i dont believe that its suspension related. any thoughts would be helpful. thanks.
Old Mar 1, 2010 | 11:05 PM
old timer's Avatar
old timer
check under the dash and see if the clinking is coming from under the dash there is a technical service bulletin about that
Old Mar 2, 2010 | 06:31 PM
mb98d's Avatar
mb98d
thanks. do you know where under the dash to listen for the sound?
Old Mar 3, 2010 | 10:37 PM
hydrashocker's Avatar
hydrashocker
More than likely there is something loose on the column. Check and re-tighten.
Old Mar 4, 2010 | 12:06 PM
mb98d's Avatar
mb98d
will do as soon as the snow melts completely. thanks
