brakes don't brighten
Old Jan 14, 2010 | 11:56 AM
ronisi's Avatar
ronisi
Default brakes don't brighten
I replaced the bulbs and brake light switch and still nothing. The only thing working is the top rear light(top of rear window) goes on when brake pedal is pushed. Is there a fuse and if there is where is it?
Old Jan 14, 2010 | 03:23 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
fuse is probably in the door jam of the drivers door, the fuses are numbered and labeled in the door panel that pulls off,
if its not there check the power distribution block under the hood, it is also labelled for ya
Old Jan 14, 2010 | 03:26 PM
Dans01Durango's Avatar
Dans01Durango
Did you replace with the right bulbs? The brake bulbs have two filaments.One for regular headlights/night driving and teh other for braking. Just asking.
Old Jan 14, 2010 | 03:30 PM
ronisi's Avatar
ronisi
Ill take a look at fuses and yes I have the right bulbs Thanks I let you know
Old Jan 14, 2010 | 03:34 PM
Dans01Durango
Then I hope you get the problem fixed. No hard feelings?
Old Jan 16, 2010 | 11:41 PM
ronisi's Avatar
ronisi
new bulbs and still not getting brighter just noticed the license plate light is burned out. gonna replace tomorrow
Old Jan 17, 2010 | 12:30 AM
hydrashocker's Avatar
hydrashocker
What year as we can look in the wiring schematics.
Old Jan 17, 2010 | 02:42 PM
ronisi's Avatar
ronisi
2002 durango R/T
Old Jan 17, 2010 | 09:46 PM
hydrashocker
I looked in schematics for a 2002 and everything I see you need to replace the combination flasher.
Reference thread:
https://dodgeforum.com/forum/1st-gen...19-fuse-d.html
