A/c Compressor
Old Jan 19, 2010 | 07:02 PM
hern615's Avatar
hern615
Default A/c Compressor
Hi Folks, My 2003 durango's a/c compressor has a mind of his own and I need to fix that. What is going on is, when I am going down the road the a/c commpressor cycles on/off without my help from inside. Does anyone have an idea of the problem?
Thanks in advance..any help will be appreciated.
Hern615---
Old Jan 19, 2010 | 07:53 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
what position is the hvac control in? is the a/c light on? is it on the defrost setting? if you have the defrosters blowing then the a/c compressor will cycle
Old Jan 20, 2010 | 12:28 AM
hydrashocker's Avatar
hydrashocker
Also could be low on freon.
Old Jan 20, 2010 | 12:43 PM
shrpshtr325
THE ULTI-MOD
i dont think i would attempt to cycle, even low on freon, if he has it turned off in the dash (i think the believes that he has the a/c turned off, i could be mistaken)
Old Jan 20, 2010 | 04:29 PM
Duranged408's Avatar
Duranged408
If it cycles only when the ac/heat is on, then yeah as he said the system is low on refrigerant and maybe have a leak.
Old Jan 21, 2010 | 12:01 AM
hydrashocker
It does it on mine.
Old Jan 21, 2010 | 12:34 AM
IndyDurango's Avatar
IndyDurango
The DEFROST will cycle the A/C.
IndyD
Old Jan 21, 2010 | 08:23 AM
Duranged408
IndyD
Yepp
But if he doesnt reply with any specifics, im almost 100% sure his spare tire is leaking thats causing the problem
Old Jan 21, 2010 | 10:03 PM
SumAmerican's Avatar
SumAmerican
He could have over filled it.. that is of course if he is trying to run the AC.. overfill or over servicing with oil will cause the compressor to shut off due to over pressure on the high side..
Old Jan 21, 2010 | 11:58 PM
hydrashocker
If the pump cannot maintain pressure by default it will compress (low R134) without A/C or defrost engagement.
