More HP's?!?!
Old Jan 21, 2010 | 02:19 PM
rjkeyser's Avatar
rjkeyser
Lightbulb More HP's?!?!
Does anyone have any suggestions on how to get more horse power out of a 99 5.9L durango motor? Im talking all, cheap, quick, easy, long, expensive, everything, even the do-it-urselfers. Anyone have any luck with a certain product, if so, where, what, and how much?! Thankyou folks.
Old Jan 21, 2010 | 03:20 PM
Duranged408's Avatar
Duranged408
408 stroker/pro-charger/transmission/heads/gears/headers/cam/n2/exhaust/programmer/intake
*highest to lowest
Old Jan 21, 2010 | 08:51 PM
gr8scott72's Avatar
gr8scott72
*highest to lowest
Of that list, the gears is the biggest bang for the buck. My truck is day and night different with the 4.56:1 gears instead of the 3.55:1 stock gears it had.
Old Jan 21, 2010 | 09:44 PM
Kensai's Avatar
Kensai
Was your MPG day and night different also?
Old Jan 21, 2010 | 09:51 PM
SumAmerican's Avatar
SumAmerican
The cheap stage 1 stuff is always where to start..
new plugs/ cap/rotor/ wires / intake / coil /
You can always keep adding.. You will get the most from getting more air into the engine.. stock exhaust is pretty good and the only thing you'll get from upgrading is a louder note..
Old Jan 21, 2010 | 11:52 PM
hydrashocker's Avatar
hydrashocker
Look here.... https://dodgeforum.com/forum/1st-gen...-your-rig.html
Old Jan 22, 2010 | 11:45 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
with what he was towing with the truck, i doubt that he noticed a difference in that deparment
Old Jan 22, 2010 | 07:32 PM
Dislander's Avatar
Dislander
Just think of the engine as a big air pump. the more you can get in and out the more power you make. I would, start with the exhaust.This is assuming you have already done all the maint stuff cap, rotor, wires(might as well get good ones). then start working on the intake side. if you can get more air in but not more out, freeing up the intake first will gain you little.
Around this point you can start to take advantage of retuning modules & when you've maxed out with bolt-on's start looking at the real power, the motor itself. cams compression ect.
A good coil would be reccomended but I don't think you'd see much from an ignition box till you crack into the motor.
Once you get past the chip other bolt-on's may gain you fractional increases but they will not register so much on the ***-o-meter.
Gears, if you can afford them & especially if you have larger tires are great for pull out of the hole (if you have larger tires you may get better mpg's) but can cost you on the highway.
Old Jan 22, 2010 | 10:26 PM
Kensai's Avatar
Kensai
I have to say that when you picture the engine as an air pump. Intake and exhaust both needs to be done. One side won't do better without the other. You can upgrade exhaust but do no good if intake is restricting and vice versa.
But for the most part, people will start with the intake first. Mainly because it is cheaper and easy to do vs the exhaust. Usually upgrading will start top of the engine and work towards the bottom.
For me, I started with replacing the paper filter for K&N factory replacement, then upgraded to a bigger throttle body, then made a custom ram air to draw more cool air. Exhaust will be one of the last things for me to do as I don't have a budget for it yet. Still working on saving up to replace the heater core and build a custom bypass for it.
If and when I do get exhaust upgrade, I will try to get a tru-dual setup or go catback by getting a much bigger diameter Y-pipe and maybe 3 inch straight pipe to the cat and muffler and then duals out from the muffler. Never been a header fan, never had one that lasted more than a couple years.
Old Jan 23, 2010 | 12:46 AM
Dislander's Avatar
Dislander
So, by virtue of the fact you do not have the exhaust done yet, you're advocating starting with the intake? or is it just a cost issue? because if you seek performance bang for buck, exhaust is the way to go. one doesn't have to buy a kit, just get a better flowing muffler. you say the stocker is a fine flowing unit. compared to what?
stock mufflers are very restrictive. designed to be pleasing to the sensitive ears of the soccer mom, not to flow at its greatest potential.
I'm not saying do a y-pipe. more would need to be done to the motor in order to justify the cost vs potential gain.
If your constipated do you stuff in more food?
