Durango rpm question
Old Jan 22, 2010 | 12:05 AM
RatFink309's Avatar
RatFink309
Default Durango rpm question
Ok so I have a 2001 Durango {my wife's car } and while cruising the interstate at about 70 or so with the cruise control on or off does not matter, well the rpm's kinda raise up about a grand or so then back down......... So the funny thing is I'm not going any faster yet the rpm's go up and down about every 15 seconds.
I shut the heat/ac off and took the cruise off and kept a steady foot and it still races up and down . I've noticed on our trip to Fla. it DOES NOT help the fuel mileage one bit either LOL ............. Any thoughts ?
Oh, and notice it's begging to do it around town also at much slower speeds but not very often at all .........
Thanks
Old Jan 22, 2010 | 12:59 AM
IndyDurango's Avatar
IndyDurango
There is a pressure gov sensor that would cause bucking in the same situation. If you are only seeing RPMs moving, replace the TPS (throttle position sensor.)
HTH,
IndyDurango
Old Jan 22, 2010 | 01:00 AM
rebelboy's Avatar
rebelboy
Talking
+1 tps
Old Jan 22, 2010 | 11:52 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
sounds like the tps to me
Old Jan 23, 2010 | 01:45 AM
RatFink309's Avatar
RatFink309
Thanks !
I will give it a try ................................
Old Jan 23, 2010 | 01:47 AM
RatFink309's Avatar
RatFink309
HTH,
IndyDurango
Yep, just the RPMs only ........................ I will check into the TPS ...
Very helpful and thank you !!!!!!!!
