some questions
I have a 99 Durango that has some issues
1. the drivers door will not lock auto but if you push down on the lock itself then it will lock. I can hear the actuator working but it is just not working?
2. my rear wiper is not working the pumpworks from the switch but not the wiper and i need to know where i need to look at first?
3. I need to know where to find a 1999 owners manual download since it did not come with one
ok lets break this down for ya
take the door panel off and make sure the actuator is not loose and the connecting rod is hooked up the lock mechanism, sounds to me like it somehow came loose
check your fuses first, get back to us and we will go from there,
ebay???? idk of anyplace that has owners manuals available for dl, we have an 02 SHOP manual floating around on here, but thats it
well the rear wiper motor is not hooked up but when i do hook it up it sounds like the relay is trying to keep running but the motor still will not turn
i am going to check out the door again this weekend when i don't work but if i remember right everything looked good so could it be an acturater it self that has went bad. because i can hit the lock button and all the doors will lock except the drivers but if i hit the lock switch and the doors lock i can push down on the lock and lock it and it will unlock just fine with the switch. any help will be greatful
well the problem is still there with the door lock but it is only the drivers door. i can hit the lock button on the door and all doors but the drivers door locks but after hitting the switch i can manually lock the door from the inside. the unlock feature works fine. is it my switch or the lock itself any suggestions would be nice. i need to get this fixed so i can put my alarm/remote start on it.
Trending Topics
The actuators in the doors will go bad after like 10-15 years.. In my neon only one works.. just gotta replace the actuator.
The rear wiper problem is a common problem for first gen durangos.. you may just have to pop the cap off and tighten the retaining nut but most likely the motors gone bad from time.. if you really wanna test it before you replace the motor i suppose you could pull the plug and put a voltmeter in there and make sure the motor is still getting juice but most likely its gonna be your motor..
as for the owners manual.. you've got a few options.. you could check ebay or a junk yard to get one (cheapest) or you could call the dealership.. i think the owners manual has a part number just like everything else.. don't hold me too that tho..
