Intermitten Transmition Issue
If you don't know to adjust the kick down cable. Don't. leave it for the pro's. You can send a pm to me like shrpshtr325 had said, I maybe able to guide you. And don't touch that idle screw.
Yeah the idiot that owned the vehicle before me messed with that idle screw... so I have to learn how to retune that.... I have no clue. But I am still having this exact issue. How do I retune that idle screw?
Yeah haven't touched the kickdown cable either. But some good advice would appreasiated.
actually will do... i will hit the junk yards tomorrow in search of 2 black passenger side doors... and the idle screw assembly lmao! . hopefully it will solve my problem. Bought a optima battery today too... noticed some change in hp and a smoother idle but again didnt solve the problem and replaced the output sensor today also. Some fine grit metal fragments on the tip... not sure if thats why it might have been acting up but still have the problem of... the very first shift is kinda wack... I have to let up on the gas to get it to shift then it shifts fine the entire trip even if i stop at a red light it doesn't act up. but that very first take off it will not shift unless i floor it at its hult or let up on the gas. Innoying as hell wish i knew a cure.
