speakers
Old Jan 31, 2010 | 02:29 PM
Spc_Sapper's Avatar
Spc_Sapper
Default speakers
i havea 99 slt 5.2 leather infinty sound and alal four door speaker are blown any idea wear i can get replcments
Old Feb 1, 2010 | 06:23 AM
Mastec's Avatar
Mastec
I ordered replacements for mine from Crutchfield
Old Feb 1, 2010 | 07:38 AM
mark38090's Avatar
mark38090
I have a 98, same infinity system and I replaced all mine with pioneer and they sound just fine...
Old Feb 1, 2010 | 07:44 AM
Dans01Durango's Avatar
Dans01Durango
Or you can read about the speakers here: https://dodgeforum.com/forum/1st-gen...lacements.html HTH.
Old Feb 1, 2010 | 02:41 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
damn it dan, beat me to it, read that thread and then decide, infinity makes speakers which are designed to be used with the stock headunits, and make sure to get the right ones (2 ohms i believe)
Old Feb 1, 2010 | 03:48 PM
Kensai's Avatar
Kensai
I mostly did most of the write up on that thread. Back then, I used infinity 4 ohm speakers. You can use 4 ohm speaker on a 2 ohm system without hurting anything. But today, the 6012's 4 ohm speakers have been replaced by the current 6022's which are 2ohm speakers.
Another alternative. As long as the voice coils aren't blown, you can replace the foam rings cheap from www.simplyspeakers.com mentioned in my thread and how to replace them.
Old Feb 1, 2010 | 10:27 PM
IndyDurango's Avatar
IndyDurango
Or just rubber cement the separated areas of the coil back in place. Nearly permanent and just a $2 fix.
IndyD
