No compression in cylinder 1
Old Mar 19, 2010 | 07:49 PM
  #21
jchaines's Avatar
jchaines
Originally Posted by 45AutoPete
You are using the same push tubes right? I would loosen up the rockers on the cylinder with no compression, remove both push tubes and make sure one is not longer than the other. Only other way you can see if the valve is higher than the rest is to loosen all the rockers on that one side, move them off to the side and place a straight edge on top of the valves. They should all be the same height and if they are not, there is your problem.
Yes, same push rods. I will do that tomorrow. Thanks!
Old Mar 19, 2010 | 07:52 PM
  #22
45AutoPete's Avatar
45AutoPete
If the one push tube is not seating in the lifter right and is sitting off to the side of the lifter, that would also cause the valve to stay opened. To check if that one push tube is seated correctly, loosen that one rocker that is giving you problems and twist that push tube to see if you can spin it freely, you should be able to feel it spin like it is on a bearing.
Old Mar 19, 2010 | 11:52 PM
  #23
hydrashocker's Avatar
hydrashocker
Great idea Pete!
Old Mar 20, 2010 | 12:22 AM
  #24
45AutoPete's Avatar
45AutoPete
Thank you
Old Mar 28, 2010 | 10:12 AM
  #25
jchaines's Avatar
jchaines
Finally got it. The remanufactured (yup, not new...) head on that side was milled just a little to much that it was keeping the valves open. Glad I figured that one out and the valves didn't hit the piston becuase of that error. This one was a stumper! Thank you guys for all the help and ideas. The Durango is running great!
Old Mar 28, 2010 | 04:51 PM
  #26
45AutoPete's Avatar
45AutoPete
Glad to give you some pointers. They really must have milled the crap out of that head for the valves to stay open esp. when you had to back the rockers off that much to hold compression. They must have had a trainee on the milling machine!!!
Old Mar 28, 2010 | 10:50 PM
  #27
hydrashocker
Nice call.
Glad to see you got it and your happy. Did you end up P&P'ing the heads?
