Donut tires!?!?
Old 02-10-2010, 07:27 PM
mrwilliwizard's Avatar
mrwilliwizard
mrwilliwizard is offline
ooh yea lol not good.
Old 02-10-2010, 10:59 PM
mrwilliwizard
Question
Old 02-10-2010, 11:23 PM
mrwilliwizard
question my tires are measured in P-metric with a load rating of say 2500lbs and the max psi for them is 44 so i have them pumped to like 35.
if i get tires measured in LT- metric the tires load rating is 2500lbs @ 80 psi. do i still pump those up to 35 psi?
Old 02-11-2010, 03:45 AM
mrwilliwizard
And should I go go with 265/75/16 size tires which is 31.7 diameter or should I go 285/75/16 which is 32.8 inches in diameter? Pros cons ?
Old 02-11-2010, 09:27 AM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
id keep it under the 32 mark, the stock tires on mine are 31's and they are extraordinarily close to rubbing (i cant even fit a finger btwn the tire and the plastic fender lining)
Old 02-11-2010, 01:38 PM
mrwilliwizard
hmm do you have the T/s lift? i currently have 31's and i could fit a bigger size for sure. I'm just worried about the 32.8' size causing suspension problems?
Old 02-11-2010, 02:16 PM
shrpshtr325
THE ULTI-MOD
i do not, i am sitting at stock ride height so that limits my options
Quick Reply: Donut tires!?!?
