Belt alignment issues
Old Feb 11, 2010 | 09:26 PM
Roughneck1860's Avatar
Roughneck1860
Default Belt alignment issues
I have a '99 Durango with the 5.2L, the serpentine belt keeps sliding towards the engine on the fan/water pump pulley. The belt is also jumping one grove towards the motor on the crank pulley. Obviously something is out of whack but I can't see what. All the pulleys seem to be ok, none are overly loose or anything. Any one have any suggestions?
Thanks
Tim
Old Feb 12, 2010 | 07:39 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Repost in the first generation Durango asection as this is the general forum. I would check to see if you are running the correct size belt,
FF
