Just replaced the oxygen sensor...
Old Feb 19, 2010 | 04:43 PM
eande78651's Avatar
eande78651
Default Just replaced the oxygen sensor...
Hi all,
I have a 2001 Durango SLT 4.7. I just replaced the upstream O2 sensor, cleared the codes and sea foamed the intake. Ran fine yesterday with no CEL's, but today it threw a new code : p0135
Any ideas? Thanks!
Old Feb 19, 2010 | 06:38 PM
mrwilliwizard's Avatar
mrwilliwizard
P0135 1/1 O2S Heater Failure
did you connect the o2 sensor correctly?
try reconnecting it. could be a bad o2 sensor?
Old Feb 19, 2010 | 07:57 PM
eande78651's Avatar
eande78651
I crawled under and reseated the connectors. Hoping its not a bad o2, its in a tight spot.
Old Feb 19, 2010 | 09:59 PM
mrwilliwizard
are you still throwing a cel?
Old Feb 19, 2010 | 10:44 PM
master tech's Avatar
master tech
Site Moderator & Tech
Also ck the power steering switch if you have one, If the switch is leaking it will leak p/s fluid into the o2 sensors and the pcm too.
Old Feb 19, 2010 | 11:52 PM
hydrashocker's Avatar
hydrashocker
Also reset the PCM.
Old Feb 22, 2010 | 09:08 AM
eande78651's Avatar
eande78651
Ok, I checked the power steering pump, no leak. I checked the o2 connectors again, and reset the PCM all was fine until today where it threw the same code again.
Old Feb 22, 2010 | 11:32 AM
Turbozcs2003's Avatar
Turbozcs2003
What kind of O2 sensor did you use??? My self I have some new mopar units sitting in a box waiting. I have heard non-oem replacments may cause issues.
How many miles on your D.
Old Feb 22, 2010 | 12:03 PM
joe_yoh's Avatar
joe_yoh
Maybe you didn't connect it properly. Check it man.
Old Feb 22, 2010 | 02:34 PM
hydrashocker
The dealer O2 sensors are better than aftermarket and the aftermarket can trip CEL's over and over.
