Oil frothing???
Old Feb 20, 2010 | 01:22 PM
jwils71's Avatar
jwils71
Default Oil frothing???
I have a 2001 Durango SLT 4.7l 4x4 w/140000 approximate miles.
I regularly check and change the oil. Lately I have noticed "frothing" on the cap and filler neck. I thought I saw a TSB on this but can't find it now.
Do I need to be concerned about this or is this just another example of bad engineering?
I can post a link to a picture if needed...
Thanks and I look forward to replies!
Old Feb 20, 2010 | 03:37 PM
IndyDurango's Avatar
IndyDurango
TSB exists. Search for "snot" or sometimes people think it is sludge. Its not but the threads often start that way.
IndyD
Old Feb 21, 2010 | 11:51 PM
brad8266's Avatar
brad8266
Replace the PCV and check the PCV system hoses for cloggage or leakage. Sludge build up is sometimes simply a PCV system that is failng to ventilate.
Old Feb 22, 2010 | 12:24 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
as indy said, it is not sludge, just a "snot" and there is a tsb on it with a fix, the fix really just causes it to set inside the cap on a baffle that catches the snot instead of dropping it back into the engine, not a problem, just keep an eye on it, and your oil level
Old Feb 22, 2010 | 10:51 AM
jwils71's Avatar
jwils71
Thanks all!
That's what I thought. The parts are already installed(baffle and cap). I was just curious.
Will do the PCV, etc to make sure my D keeps running smoothly.
Mod can close the thread...
Old Feb 22, 2010 | 02:32 PM
hydrashocker's Avatar
hydrashocker
I don't close threads unless there is issues beyond control. It will just drop off the page so don't worry.....LOL
Old Feb 22, 2010 | 09:59 PM
IndyDurango
If you have had the TSB completed, it should not be all snot filled. I would check the TSB steps again. Part of the TSB is to swap the PCV.
IndyD
