Broken
Old Feb 27, 2010 | 02:48 PM
bain64's Avatar
bain64
Default Broken
Well fix one problem, cause another.. I replaced the PCV valve, and looked over at the drivers side of the motor and saw what looked like a second valve. I pulled on it a bit and the plastic broke. The hose runs from there to the air intake just before the throttle body. I'm heading to the auto store now but fear that it will be a dealer only part. Any ideas on how to remove it once i get the part? I tried some pliers but the thing just falls apart when pulled on. Can i remove that rubber o-ring around it? I pried on it with a screwdriver some but didn't feel like i was getting anywhere..
Old Feb 27, 2010 | 03:39 PM
hydrashocker's Avatar
hydrashocker
Get a flat head screw driver and pry the whole thing out careful not to drop any pieces inside. That is a breather and not a second PCV valve, you have to go to the dealer and get a new one. Also pick up new graments while your there. Also that hose "if you need to replace it" is a dealer item as well as it is a pre-bent hose.
Old Feb 27, 2010 | 04:02 PM
bain64's Avatar
bain64
OK, got the parts from the dealer. But I can't get the darn thing out. It will spin around in the grommet, but if I try to pull it out with pliers small pieces break off. Back outside to mess with it some more..
Old Feb 27, 2010 | 05:37 PM
bain64's Avatar
bain64
Got it out finally. I had to completely break the plastic ring off the elbow and allow it to fall into the valve cover, and then tear the grommet to get it to release and then pull the elbow out. I ended up with a few tiny fragments inside of the valve covers, I used my finger to touch and pull out everything I could. Crazy how a "simple" job of pulling out an elbow and replacing can be so rough. I think if it had been the middle of summer instead of winter it would have been a quick job.
Anyways lesson of the day: Don't touch the breather on the driver's side valve cover, it is very brittle!
I'll try and stop in to say hello more often on the Durango side of the forum, instead of just showing up when I have problems. It is the wife's ride so I usually hang out in the Dakota section.
Old Feb 28, 2010 | 01:57 AM
IndyDurango's Avatar
IndyDurango
Not quite. 2000-2003 The drivers side **IS** the PCV valve. The similar plastic breather elbow you broke is on the passenger side.
FWIW, most may not want tiny (or larger) pieces of plastic in the heads. Either take the valve cover off and take it out OR link the two broken sections with a small piece of hose. Nothing goes through the but air and that would be fine.
IndyDurango
Old Feb 28, 2010 | 02:26 AM
bain64's Avatar
bain64
The 99 with the 318, which we have, the breather is on the drivers side. The PCV valve is on the passengers side. I did not want any pieces in the valve cover either, but since i kept trying to pull it out with pliers this is what happened. If i were to do it again, and did not want to spend the time removing the valve cover (and all other hoses in the way), breaking the plastic upper ring off the elbow with a screwdriver and allowing the elbow to drop into the valve cover just enough to allow removal of the grommet that holds it in place would be the most efficient method. This is the method that used, I just would not have kept trying to pull it out with pliers. Every pull I made, the plastic would break exactly where I had the pliers, no matter what kind of prying action I applied with a screwdriver while pulling.
Old Feb 28, 2010 | 02:41 AM
IndyDurango
98 & 99s are that way. Opposite of the 2000+
IndyD
Old Feb 28, 2010 | 07:20 PM
hydrashocker
Their a PITA to get out when they are brittle as I ran into the same issue......A picture says a thousand words!....LOL
