Speed Sensor question 1999
Old Feb 28, 2010 | 04:24 PM
georgia's Avatar
georgia
Default Speed Sensor question 1999
Have a 99 durango and the speedometer is not working at all--check engine light came on and code was for speed sensor. Now the ABS light is not on-the only light on is check engine. Replaced sensor on side of trans and still same problem.
After reading I see there is another sensor on rear diff, where exactly and is it the same part as trans one?
thanks
Old Feb 28, 2010 | 05:27 PM
95_318SLT's Avatar
95_318SLT
The sensor in the rear axle is at the top of the pumpkin directly above where the ring gear is located.
Old Feb 28, 2010 | 05:55 PM
tst31's Avatar
tst31
I had the exact same issue with my 99' and issue was solved when replaced the rear wheel speed sensor, which is a different part. It's actually a very simple fix, less then 10 minutes, and much cleaner than the tranny side sensor.
Old Feb 28, 2010 | 07:14 PM
georgia's Avatar
georgia
Ok thanks guys....so its a different part than the tranny speed sensor?
Old Feb 28, 2010 | 07:43 PM
hydrashocker's Avatar
hydrashocker
Replace the rear differential speed sensor located on top of the rear diff like everyone is stating.
Old Feb 28, 2010 | 09:11 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
yup +1000000000 rear speed sensor
Old Feb 28, 2010 | 09:34 PM
georgia's Avatar
georgia
Thank you.
