rough running 99 Duro
Old Feb 28, 2010 | 10:57 PM
ditchplied's Avatar
ditchplied
Default rough running 99 Duro
I've done the plugs, wires, rotor button, injector cleaners. Still runs rough. no codes are triggered either. don't have a pressure tester. it is a steady rough making me think it may be a bad cylinder or bad timing. your thoughts? I'm baffled.
Old Feb 28, 2010 | 11:19 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
you replaced the cap and rotor with one that has brass contacts?
after that check the crank or camshaft position center as they control timing
Old Mar 1, 2010 | 08:11 AM
Dans01Durango's Avatar
Dans01Durango
X2 what he^ said.
Old Mar 1, 2010 | 09:27 PM
old timer's Avatar
old timer
try cleaning the throttle body and replacing the pcv valve mine was idling rough and that fixed it
Old Mar 1, 2010 | 10:17 PM
IndyDurango's Avatar
IndyDurango
Check for a vacuum leak. Use a handheld propane torch, no flame, listening for changes in idle as you pass the open propane past a vacuum in take of fumes.
IndyDurango
Old Mar 2, 2010 | 12:00 AM
hydrashocker's Avatar
hydrashocker
Did you use OEM parts or aftermarket?????
