Need HELP
Old Mar 25, 2010 | 10:48 PM
  #21
IndyDurango's Avatar
IndyDurango
No comment has been provided as to whether the battery was PROPERLY eliminated.
[/out]
IndyD
Old Mar 25, 2010 | 11:22 PM
  #22
hydrashocker's Avatar
hydrashocker
Yep,
Check that battery!
Old Mar 26, 2010 | 08:34 AM
  #23
Kevin Murphy's Avatar
Kevin Murphy
Yes I did load check the battery and change the relay. Have not checked the fuel pressure again. I think I will check the fuel pressure and change the relay back. Do you think it is the computer?
Old Mar 26, 2010 | 10:59 AM
  #24
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
unlikely if the relay is clicking, most likely a bad ground connection, so also check all the grounds, especially the ones going to the PDC, ALL of the battery terminals, and follow the wire harness form the fuel pump to see if there are any loose/dirty connections, yes a ****ty job but cheaper than throwing parts at it
Old Mar 27, 2010 | 08:51 AM
  #25
Kevin Murphy
Default Getting closer to the end
"THE D IS DEAD" last night the D died I tried to start it with no luck. It was a long cold walk home. the gas gage does not come up or read and you can smell the gas but the car will not run. I guess I will tow it home today. I am thinking it may be time to scrap the D.
Old Mar 27, 2010 | 11:21 PM
  #26
hydrashocker
Scrap the D over a bad fuel pump!
Just replace it and clean the connections real good while it's down.
Old Mar 30, 2010 | 10:51 PM
  #27
bko426's Avatar
bko426
it might be the heater core idk about the D but i had a 93 blazer with all this stuff happening and it ended up being a hearter core
Old Apr 10, 2010 | 09:35 AM
  #28
Kevin Murphy
Exclamation What do you think Guys
Just talked to a D specialist and he told me that the D's have a problem with the ignition module wiring. this will give me all the problems I have been having. He said that I have to cut the wiring back 6 inches and replace it?
O-yea Where is the ignition module.
Old Apr 10, 2010 | 10:12 AM
  #29
shrpshtr325
THE ULTI-MOD
i have never heard this so im going to raise the and id get a second opinion on this guy, he worries me after saying that
Old Apr 11, 2010 | 01:52 AM
  #30
IndyDurango
Your ignition module eh?
We don't have an ignition module. We have a PCM that controls the ignition via input from the TPS and the CPS.
LOL
Scrap that guy, scrap your battery, replace them both and drive away.
6" of wiring... LOL
IndyD
