Windows/locks won't work?!?!?
Old Mar 16, 2010 | 12:55 AM
im-rich-bich's Avatar
im-rich-bich
Angry Windows/locks won't work?!?!?
So my durango has been sitting in the garage for a minute and when I get in it and fire it up, I realize that the windows and the locks won't work off of any of the switches in the car. I looked around for any blown fuses but found none. Oh yeah and the car will lock/unlock with the remote. I don't get it. It's driving me crazy trying to figure it out any help is welcome.
Old Mar 16, 2010 | 09:54 AM
Dans01Durango's Avatar
Dans01Durango
Try looking into the master switch on the driver door. Sometimes wires can work loose over time. Use a flathead to gently pry it off the armrest and check the connections. HTH.
Old Mar 16, 2010 | 08:43 PM
IndyDurango's Avatar
IndyDurango
+1. Bad master door switch is the first place to look based on your description.
IndyDurango
Old Mar 16, 2010 | 11:17 PM
hydrashocker's Avatar
hydrashocker
+2 on the master drivers side switch.
Old Mar 17, 2010 | 02:12 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
+3 on the master switch in the drivers door
Old Mar 17, 2010 | 11:08 PM
bigd101's Avatar
bigd101
+4 on the master switch. I had to get mine replaced. It happened within the first week of when I bought mine and I called the dealership and they replaced it for free. I was glad!
Old Mar 17, 2010 | 11:51 PM
im-rich-bich
Ok I will look into it, so if it is the wires I could just soder them back right
Old Mar 18, 2010 | 09:38 AM
shrpshtr325
THE ULTI-MOD
there is a plug on the master switch no soldering necessary, just unplug old one remove and throw away, plug in new one and snap back into door and you are good to go
Old Mar 18, 2010 | 07:35 PM
45AutoPete's Avatar
45AutoPete
+1 Once any kind of moisture gets to the circuit board on the Master Switch, it is a goner!!
Old Mar 18, 2010 | 09:29 PM
redfernclan's Avatar
redfernclan
I just drove mine last week and the same thing happened. Anyone know if there is a better switch out there? Normaly I stick with OEM because it is made pretty well, but in this case, there might be a better one out there.
