Got sum biggah rubbah, speedo is off!!
Old Mar 24, 2010 | 02:02 PM
Dans01Durango's Avatar
Dans01Durango
That would be my guess. Cause the height affects the circumfirence of the tire.
Old Mar 24, 2010 | 03:30 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
that is correct, but im not sure on which number is which on the tire size, all i know is the last one is rim diameter
Old Mar 24, 2010 | 05:34 PM
03R/T's Avatar
03R/T
Case in point my factory tire size. 275/60/17
275= tread width
60= this is sidewall height, 60% of tread width
17= Diameter of wheel
Old Mar 25, 2010 | 12:18 AM
hydrashocker's Avatar
hydrashocker
Well I'm drunk right now and havin fun so there!
This **** is too hard right now to figure so I say this,
Okay, which do you like better..Superchips or the Hypertech? I see Facory has a hypertech for sale...HMMMMM
Jump on it and it will fix your issues and make you very happy in the process!
Old Mar 28, 2010 | 05:12 PM
backwallkiller's Avatar
backwallkiller
Originally Posted by 45AutoPete
Width is the 75R, tire height is the metric numbers in front like the 245 versus 275. A 65R will be wider and also a 55R is wider.
if the 275 is the height and 75 is the width... then why is it a 40series tire looks like a rubber band on a rim and a 75 looks like a swamper.. and a 205 looks like a bicycle tire and a 325 looks like a drag slick?? just 2 cents
Old Mar 30, 2010 | 02:35 AM
03R/T's Avatar
03R/T
Please see post 13, all will become clear
Old Apr 1, 2010 | 03:06 PM
thorze's Avatar
thorze
Wow! This went in a funny direction. I hope everyone understands there metric tire sizes now LOL.
Anyway, I got the tuner from Facory hooked it up and as it was reading, my guages went dead and my odometer started blinking just like it did when my computer junked on me, but all was good after it finished programming and holy flaming crap on a stick!!!! I got a very nice boost in the pedal as well now when I say HAH mule it really is like I'm hitting her with a stick !!!!
Thank you Hydra for the suggestion and fix on the speedo, by the way hows that new truck treating you??
Old Apr 2, 2010 | 12:39 AM
hydrashocker
Loven the new truck and your welcome.
Been playin with the truck and I have it responding like a lonely horny chick......LOL
Anyway, Thinkin about doing a B&G flash for my PCM (concitering nobody makes a tuner for me) but first I think I'm savin up for a gearing swap to 4.10 from 3.55 for starters.
Old Apr 2, 2010 | 10:20 AM
02 Durango_R/T's Avatar
02 Durango_R/T
When I change tire sizes on my lifted Jeep, all I have to do to correct the speedo was change the little speedo gear in the transmission tail under the Jeep. At the most it's an "un-messy" 20 minute job ... if you're slow. The tooth count on the speedo determines which one you need for the specific tire size. Is it possible to do this with the Durango as well?
Coincidentally the speedo gear I got off ebay was listed as a Dodge gear and it was identical to mine. Fit perfectly.
Dodge gear is the green one. Size differes due to tooth count. Orange is Jeep stock.
Old Apr 2, 2010 | 12:04 PM
hydrashocker
Speedo is controlled at the rear diff by an exciter ring on the carrier and a pick up sensor on the Ram, Durango, and Dakota. The only way would be to program the PCM or *possible exciter ring tooth swap* (just looking into that so unsure).
