trailer wiring
Old Mar 28, 2010 | 06:44 PM
tattoodbrute's Avatar
tattoodbrute
Default trailer wiring
hello all, new here, just picked up a 2000 durango 4.7, just put a trailer hitch on now can't find the wiring harness, or where do i splice a connector to or hook a factory one to thanks in advance
Old Mar 28, 2010 | 09:14 PM
tattoodbrute
anyone ????????
Old Mar 28, 2010 | 11:13 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
dude, 3 hours is not enough time to get a response, give us a chance to read it and get back to you
here is the wiring diagram from the shop manual http://www.mediafire.com/?zqzqwt20om2
you should be able to tap into the wiring at the rear tail-lights for the majority of the connections but i have not looked into it myself so be careful with what you do.
Old Mar 28, 2010 | 11:36 PM
hydrashocker's Avatar
hydrashocker
Give us some time.
Your harness should be above the spare tire or drivers side frame region so look real good in that section as it is usually tucked up in that section.
Old Mar 29, 2010 | 07:15 PM
tattoodbrute
sorry guys i was just frustrated with this thing already, i bought a plug and go deal for a dakota thinking it was the same but is not, no dual plug ins behind bumper, i will check under spare tire and along drivers frame, also couldn't get the link to open for the wiring diagram any idea why????
Old Mar 29, 2010 | 08:37 PM
shrpshtr325
THE ULTI-MOD
its a download link, works fine for me, you need adobe acrobat to open the file
Old Mar 30, 2010 | 12:43 AM
hydrashocker
You can try Firefox browser as I've had to use it before.
Old Mar 30, 2010 | 01:35 PM
shrpshtr325
THE ULTI-MOD
hydra, you should be using firefox as your main browser, its what all the smart(sober?) ppl do
Old Mar 30, 2010 | 07:00 PM
tattoodbrute
i try to download but says its broken and can't fix it
Old Mar 30, 2010 | 11:34 PM
shrpshtr325
THE ULTI-MOD
hmmm thats odd did you click open when the download option came up or did you save it to your hard-drive then try opening it hydra, does it work for you or do i need to upload it again?
