1999 Durango Rear A/C not working
Old Apr 2, 2010 | 05:29 PM
sablepilot's Avatar
sablepilot
Question 1999 Durango Rear A/C not working
Hey all...up until a couple days ago, the rear overhead A/C worked great and even had the lights to the switch working. It appears there is no power getting to the switch. My original thought was a fuse, however, I cannot find a fuse for it. The book does not address it...all it says is the rear overhead A/C works when the front A/C is on.
Any help would be appreciated.
Thanks in advance, tim
Old Apr 2, 2010 | 11:14 PM
hydrashocker's Avatar
hydrashocker
Check fuse #5 in the PDC under the hood. Also swap your A/C relay with one of the same number.
Old Apr 3, 2010 | 03:33 PM
tm985's Avatar
tm985
Follow up on this one if possible if that worked, I'd be interested to know.
Old Apr 29, 2010 | 05:42 PM
sablepilot's Avatar
sablepilot
nope...didnt work. The fuse was fine and the relay is good too.
Old May 1, 2010 | 05:33 PM
hydrashocker
See if you have power at the switch.
