Aftermarket Exaust
Old Apr 3, 2010 | 11:00 PM
Chronic01505's Avatar
Chronic01505
Default Aftermarket Exaust
Any paticular kit anyone would recommend? I've never upgraded exaust before. I would probably purchase on ebay, but I'm unsure of a quality brand and setup. The stock exaust will eventually need to go. Thanks for any suggestions.
Old Apr 4, 2010 | 12:55 AM
hydrashocker's Avatar
hydrashocker
Depends on what kinda sound you want? Loud and obnoxious, softer, or grunty. Most of the time a muffler shop will out bid a bolt on from Ebay......"My 2 cents"
Old Apr 4, 2010 | 03:04 AM
03R/T's Avatar
03R/T
I'm looking at magnaflow right now, at least the muffler. I want to do a dual side exit exhaust, ahead of the rear tire.
Old Apr 4, 2010 | 03:19 PM
hydrashocker
Go to your local muffler shop and ask em how much to install a system from the "CAT Back" in 3 inch. The Aluminzied coating pipes tends to protect it from corroding to soon and they should outlast your ownership but without the cost of Stainless Steel. Now the Muffler (MagnaFlow) is going to be Stainless Steal. They make a muffler that is a single in (which off the CAT will be 3") and dual 2 1/2" out and it will flow great. You could do a single 3" outlet pipe on that as well.
The OEM CAT flows fine but if you want to do a Hi Flow CAT then have em cut the old "Y" pipe out and MagnaFlow makes a 2 1/4" X 2 1/4" X 3" "Y" pipe then go into a 3' CAT and continue to the 3" muffler then continue out as you wish as stated above. You could also use the Advanced Search Function to find MANY threads on this topic.
Old Aug 30, 2010 | 06:32 PM
rovert812's Avatar
rovert812
or just cut the muffler off and have a muffler shop put in a pipe (straight pipe!) thats what i did with my 4.7 and it sounds BA pops like a mother if u get on it but other that it makes heads turn!
Old Aug 30, 2010 | 07:34 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
bad idea, you need some back pressure on the system in order for it to work correctly (besides you are probalby breaking a law about the volume of the exhaust)
Old Aug 31, 2010 | 07:23 PM
smokersteve's Avatar
smokersteve
Do you want an entire system????? what do you want for how much??
Old Aug 31, 2010 | 10:44 PM
hydrashocker
This tread is too old: 04-04-2010
Long and lost ago.......
Old Sep 1, 2010 | 02:31 AM
smokersteve
didnt even look
