new kid...turbo my durango???
Turbo off the cumin's will be too big, spool up lag would be horrific. even with a turbo to use you still need at least a custom y-pipe to hook the thing to, then oil & coolant lines. once the thing is in physically you still need to tune the engine management system to deal with the boost. you'd be looking at a couple thousand & still be severely limited on what you can run for boost pressure.
Better bet would be two smaller turbos one off each manifold but engine management would still be custom all the way.
Better bang for the buck with a performance engine rebuild, good cam, heads ect..
My 2psi
My 2psi
