Power Point fuse help!
Can anyone tell me the location of the 20 amp fuse for the powerpoint on the dash (at at the back) of a 2000 durango 4.7 4x4. I have gone through every fuse under both the hood and on the side of the dash.
I have tried the search on the forum but no luck
Chris
Chris
try the back of the fuse block under the dashboard there is a 'hidden' fuse block in there that might have the fuse you need,
and when you checked the fuse please tell me you did not do a visual check but actually used some sort of test meter to check them
