1999 starts but wont stay running.
Old Apr 24, 2010 | 01:45 AM
Martin Wolf's Avatar
Martin Wolf
Default 1999 starts but wont stay running.
Hello, I have a 1999 Durrango and it will turn over fine but will not stay running without giving it gas. Could this be the idle air control valve? Thanks!
Old Apr 24, 2010 | 08:41 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
it could be that IAC, it could also be a weak battery (believe it or not enough juice to turn the truck over could still be too weak to keep it idling)
Old Apr 24, 2010 | 10:39 AM
bwdakrt's Avatar
bwdakrt
Have your battery load tested and you'll probably find you have a cell going bad. These trucks like to have a fully charged battery or they will not run. While you're at it, have the alternator checked for voltage output which should be in the 13.5-14.5 range. Any parts store should do this free of charge.
Old Apr 24, 2010 | 02:57 PM
hydrashocker's Avatar
hydrashocker
+1 on that!
If everything is good then clean the TB and clean or replace your IAC.
Old May 1, 2010 | 09:02 PM
Martin Wolf
Hello and thanks, I installed a new IAC which was all gummed up and cleaned the terminals while I was at it, seems as if it is back to running like the day I bought it.
Old May 1, 2010 | 09:11 PM
SumAmerican's Avatar
SumAmerican
i was gonna say alternator.. but glad you got it fixed right the first time.. thanks for the update too
Old May 2, 2010 | 12:54 PM
hydrashocker
Glad to see you got your fix!
See ya around the boards!
