Rotors
Old May 4, 2010 | 12:02 PM
smokersteve's Avatar
smokersteve
Default Rotors
How much for a replacement? One of mine is warped, I would like to take it to Kregan's and have them machine them for $15 each, unless buying new is not much more.
Thank you
Old May 4, 2010 | 01:22 PM
Trapstud's Avatar
Trapstud
From autozone they are $35-$50.
Old May 5, 2010 | 12:18 AM
hydrashocker's Avatar
hydrashocker
take em in and see if they can be turned.
Old May 5, 2010 | 01:05 AM
Dans01Durango's Avatar
Dans01Durango
Yep, have them turned first. If not doable, get the AZ gold rotors and pads or equal from your local auto parts store.
Old May 5, 2010 | 11:34 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
if you are not changing the pads have the turned, but i usually shy away from turning the rotors simply bc once they have warped the integrity is compromised and they WILL warp again, its just a matter of when, you may get lucky and be fine, but chances are that you wont and will end up with them warping again (turned rotors are also thinner than they were originally designed to be, so they will heat up quicker which will also help them to warp more easily) just FYI
Old May 5, 2010 | 11:52 AM
smokersteve
Thanks guys I am giong to get new rotors for $20
Old May 5, 2010 | 03:53 PM
chadar74's Avatar
chadar74
we just put new rotors and ceramic brake pads on. my rotors were warp to. The ceramic brake pads are awsome!!
Old May 5, 2010 | 06:42 PM
Uller God's Avatar
Uller God
Went through 3 sets of warped rotors until I finally had it. Installed a set of cryo and never had a problem since. I highly recommend it. Clicky link
Old May 7, 2010 | 11:02 AM
smokersteve
Thank you very much. Which rotor/drum set did you chose?
Old May 7, 2010 | 01:27 PM
hydrashocker
I like regular disks (that are thick) and a set of Duralast Gold Series pads from Auto Zone. They work great for towing, city, hills, and all around use without *******ly ANY dust. I've talked many people into buying them and EVEYONES been more that happy. They are a Ceramic/Metallic mix, but they are better than both.
Most issues with the front brakes warping is because of crappy pads or the rear brakes not working correctly, so check your ware on the shoes or pads on the rear.
