Broke the crankshaft position sensor off in the block...
Old May 12, 2010 | 05:00 PM
shiftmx6's Avatar
shiftmx6
Default Broke the crankshaft position sensor off in the block...
I was in the process of replacing my crank sensor in my 4.7, and all of a sudden, it snapped off. It's about a quarter of an inch deep in the hole. Is there any way to get this out without dropping the oil pan and tapping it from behind?
Old May 25, 2010 | 11:00 PM
n8ech's Avatar
n8ech
Shift:
If you have not already, soak the heck out of it with some good pentrating oil. Then, thread in a fairly coarse wood type screw of some type until you get a good firm bite.
Then work/wiggle it back and forth till it comes out. Might take some time, but if you can keep from pulling the oil pan, it will be worth it.
Don
