low oil pressure problems
Old May 18, 2010 | 06:34 PM
kc2002's Avatar
kc2002
Default low oil pressure problems
2000 dodge durango 4.7 220,000kms, when driving or idling the truck the oil pressure drops off of to 0 and then somtimes returns back to just under the centre mark. i have already had the heads of this car and there wasnt really any sludge, not sure whats in the oil pan though??? is this a problem with the oil pump??? thanks for any help.
Old May 18, 2010 | 07:58 PM
hydrashocker's Avatar
hydrashocker
Check into this: https://dodgeforum.com/forum/1st-gen...-pressure.html
I would replace the pump i think tho.
Old May 18, 2010 | 10:28 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
yup iw ould lean towards a new pump as well
Old May 19, 2010 | 07:23 AM
dannyd97gst's Avatar
dannyd97gst
I would run a manual oil pressure check before going through the trouble of replacing an oil pump. The oil pressure gauge in our vehicles is more for driver entertainment than an accurate oil pressure reading. For example 4psi at idle is "safe" and a 4.7 will run 25-100 psi at 3k rpm. Plus the oil pressure switch is really just an on off switch anyway.
Old May 19, 2010 | 12:28 PM
45AutoPete's Avatar
45AutoPete
The oil pressure sending unit is not an on/off switch. It actually operates like a rheostat and works off of the grounding principle. More pressure equals more ground to send to your gauge. If you took off the wire on the sending unit and grounded it, your gauge would peg all the way over, real fast way of telling if your gauge works or not.
Old May 19, 2010 | 04:16 PM
hydrashocker
hmmmmm
Nice way of testing the gauge.....lol
Old May 19, 2010 | 04:40 PM
45AutoPete's Avatar
45AutoPete
I used to test fuel sending units the same way. LOL
