piece of ****!!!
Old May 23, 2010 | 02:39 PM
backwallkiller's Avatar
backwallkiller
Default piece of ****!!!
i went to the store and my battery died. so i jumped it off and got home and turned it off.. now it has nothing except and clicking noise... anyone know what this could be.. no power at all.
Old May 23, 2010 | 03:31 PM
45AutoPete's Avatar
45AutoPete
Batteries usually die from being old and needing replacement. Check charging system first and replace battery.
Old May 23, 2010 | 05:14 PM
Duranged408's Avatar
Duranged408
Jump starting and running the vehicle for a little while cannot and will not charge the battery. The output of the alternator is more a top off type of charge rather than a charger. If a battery looses a plate it can easily cause issues, just replace it.
Old May 23, 2010 | 05:44 PM
hydrashocker's Avatar
hydrashocker
Originally Posted by backwallkiller
my battery died
Replace the battery and clean the connections.....
Old May 23, 2010 | 07:51 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
replace the battery and it should be fine, if not THEN start looking at other problems, you cannot charge the battery (from dead) off the alternator PERIOD
Old May 24, 2010 | 08:14 AM
Dans01Durango's Avatar
Dans01Durango
What they all said, also check to see if you have a steady drain from your battery. Did you install an aftermarket stereo system or some other high drain electronic device(s). That would darin your battery. Also, get a battery tender and plug that into the battery if you leave the D in the garage for long periods of time.
Old May 26, 2010 | 06:29 AM
backwallkiller
well i went out shaken my head at it... and i jumped it off again.. and now its runnin fine i think my cables were loose... thanks for all the info
Old May 26, 2010 | 04:14 PM
hydrashocker
Ummmm ^^^
