Transmission Noise
Old May 25, 2010 | 06:13 PM
hydrashocker's Avatar
hydrashocker
When was the last time you changed the trans fluid and filter?
Old May 25, 2010 | 06:56 PM
Gorhad's Avatar
Gorhad
We have only just got the vehicle 2 weeks so i dont know the prior history to that.
Old May 26, 2010 | 03:41 PM
hydrashocker
Well maybe you should drop the pan and take a look in there. Replace both filters and add ATF+4 (6-8 quarts). Look for metal fragments and such on the magnet.
Old Jun 6, 2010 | 08:27 AM
Gorhad's Avatar
Gorhad
Would it need to be flushed?
Old Jun 6, 2010 | 08:30 AM
Gorhad's Avatar
Gorhad
Sorry my other question was are there 2 filters. I know there's one in the pan!
Thanx
Old Jun 6, 2010 | 09:34 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
do NOT flush the trans on ANY Chrysler motors product
and yes there are two filters, one is alot like the stock air filer (shape wise) and the other should be a spin on type filter (like an oil filter) change them both
Old Jun 6, 2010 | 01:54 PM
master tech's Avatar
master tech
Site Moderator & Tech
Gorhad
The noise you are hearing,does it sound like a ratchet? And if you have only had the truck for 2 weeks, If you send me a pm with the last 9 of the vin i can ck warranty history. Along with mileage.
Old Jun 6, 2010 | 03:55 PM
Gorhad's Avatar
Gorhad
Ok found the other oil filter after dropping the pan, changed all parts 2 fiters and gasket. Added 7 and a bit qts ATF+4. No leaks at all, drove it for about 10 miles and everything seemed fine. Fingers crossed.
When i dropped the pan there was no magnet in there so went to ace hardware a got a 25 pound disc magnet and put it in hope thats OK
Old Jun 6, 2010 | 04:07 PM
hydrashocker
That was too big. The magnet is just a small one in there on the bottom of the pan. Seeing that it might not be there means someone must have serviced the trans at a point in time and removed it and that is what was causing the issue. If you have floating metal pieces in there it will cause lots of gremlins.
Old Jun 6, 2010 | 04:50 PM
Gorhad's Avatar
Gorhad
The old fluid was very clean when we dropped the pan. It was a nice pinkesh color.
So should i drop it again and put a smaller magnet in there?
