A/C works sometimes
1999 Durango A/C works sometimes then compressor cuts out
I have a 99 Durango and I noticed the air conditioning would sometimes get warm, this just started happening this year, so I thought it was low on freon. I picked up a can at the auto store and I made sure to get a can with a guage to check the pressure. The pressure seemed fine, was in the blue, but I added the can just in case. The pressure stayed fine. Anyway, it seemed to work only to find out the next day it started getting warm again. This time, I kept the engine running when I got home and checked under the hood. I noticed the compressor wasn't running. Although it was running earlier, since it was blowing cold air and when I checked the pressure before and added the can of freon, the compressor did kick on and off. I'm at a loss on what it could be. Is there a temperature sensor tied to this that may have gone bad? Appreciate any suggestions on what to check.
Thank you.
Brian
Thank you.
Brian
