2002-2003 DVD System into 2001?
Old May 29, 2010 | 11:35 AM
thomsonc's Avatar
thomsonc
Default 2002-2003 DVD System into 2001?
Does anyone know if the 2002-2003 Mopar DVD entertainment system be retrofited into a 2001 Durango?
Old May 29, 2010 | 03:04 PM
schusterjo's Avatar
schusterjo
First time i seen this question... body style is the same so I know they used different computer system in the 2003 but am not sure about the wiring harness itself. Perhaps someone else will have the answer.. sorry could not be much help
Old May 29, 2010 | 03:40 PM
thomsonc's Avatar
thomsonc
Thanks for you input though. I know at least for 98-00, this would not be possible if there was the rear a/c unit, as it was completely different from the 01-03 version, and would actually get in the way of the entertainment system.
Old May 29, 2010 | 06:04 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
if it fit in the 02-03 durangos then it SHOULD fit in the 01s afaik
Old May 31, 2010 | 08:24 PM
IndyDurango's Avatar
IndyDurango
Yes it will work. Just grab all the wiring too. Sometimes, there is even mounting and wiring already in the headliner depending on which overhead console you have, that stuff is just not connected to anything.
IndyDurango
