Turn signals, help!!!!
Old May 29, 2010 | 06:08 PM
daddysd's Avatar
daddysd
Default Turn signals, help!!!!
I have a problem with my turn signals on a 99 durango. when i turn on the left turn signal the tail lights on the right side blink with it. also, when i turn on the lights and turn on the left turn signal, it stays on and does not blink. i have replaced all the lights and checked my connections. i am at a lost, any help would be great!! thanks
Old May 29, 2010 | 06:10 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
well start by only posting one thread about it, and two, it sounds like the flasher unit is bad
Old May 29, 2010 | 06:14 PM
daddysd's Avatar
daddysd
sorry, thought i posted it in the wrong place.
is it under the hood or in the fuse panel?
Old May 29, 2010 | 06:51 PM
schusterjo's Avatar
schusterjo
it is behind the fuse panel, u have to get on the floorboard an look behind the fuse panel an u will see it.. just turn the flasher on an get on the floorboard look up an listen for the clicking...
Old May 29, 2010 | 10:20 PM
shrpshtr325
THE ULTI-MOD
bingo he is correct
Old May 30, 2010 | 02:34 PM
daddysd's Avatar
daddysd
okay, so i found it. i went to get a new one and one store tells me i need a 30 dollar oem flasher. yet the other tells me i can get the 15 dollar one off the shelf and it will work. the 30 dollar one i need to order and won't be in till the end of the week. do i need to go to the dealership and skrew the parts stores or what??
Old May 30, 2010 | 05:14 PM
schusterjo's Avatar
schusterjo
LOL u should not need to a OEM part.. They have aftermarket ones that work fine
Old May 30, 2010 | 11:08 PM
shrpshtr325
THE ULTI-MOD
yea the aftermarket unit should work just fine, just take the bad one in with you and make sure that the part physically matches (the plugs are the most important)
Old May 30, 2010 | 11:15 PM
daddysd's Avatar
daddysd
will i took the old one with me, they did a part number cross reference and it came up with the 30 dollar one. the plugs did match on the aftermarket one. i will try it, its only 15 bucks. thanks for the help everyone!!
Old Jun 3, 2010 | 08:59 PM
daddysd's Avatar
daddysd
I got it!! after chasing wires replacing a flasher, i looked at my trailer hook up to find a wire that had rubbed off and was shorting out against another. thank you guys for the help!!
