vibration
Old Jun 5, 2010 | 09:56 PM
daddysd's Avatar
daddysd
Default vibration
i have a 99 durango with a 5.2 and an automatic. around 65-80 i have a vibration coming from the rear of the truck. it is not so bad that it hurts something, just very annoying. i just had new tires and new rims put on that balanced out perfect and an alingment done. it only does it at interstate speeds. any ideas where i can start. i thought maybe to have the driveline balanced? god i hope that i do not have a bent axle. any suggestions.... thanks
Old Jun 5, 2010 | 10:40 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
well a bent axle would be felt at most speeds, and a driveline balance should get worse as you go faster not disappear, although i will ask if you have taken the truck off road in the mud that you may have dirt or something stuck in the system (maybe even inside a rim)??
next i would check to make sure the differentials still have enough fluid in them and that it is relatively fresh
then look at u-joints and bearings (axle bearings int he differential, or at the end)
Old Jun 6, 2010 | 12:52 AM
hydrashocker's Avatar
hydrashocker
If the vibration comes and goes at different speeds and such then it is 95% a bad U-joint.
Old Jun 6, 2010 | 12:59 AM
daddysd's Avatar
daddysd
awesome, thanks for the help. i had been playin in the mud, but i washed all the rims out before i left on the road. also, the vibration gets worse the faster you go. 80 is the top i went and it was really annoying, slowed to 75 and it was tolerable. i will check my u-joints and bearings. again, thanks. this forum has always helped me when i need it.
