Rancho RS9000XL Shocks
Old Jun 5, 2010 | 11:24 PM
WhiteWidow00's Avatar
WhiteWidow00
Default Rancho RS9000XL Shocks
Anyone know if they're compatible with the 2WD D? I have a 2000 with the 5.9 if that makes a difference with anything.
Old Jun 6, 2010 | 09:20 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
you should be able to get a set for the 2wd truck, but the fronts are different than on the 4x4 model
Old Jun 6, 2010 | 09:35 AM
WhiteWidow00
So you think if I were to get RS9000XL on the back and maybe RS5000 on the front that would work on the back? I know from the rancho website the 5000 are compatible. Mainly looking for the 9000s adjustibility to make it stiff for towing, and soft for highway driving.
Old Jun 6, 2010 | 09:57 AM
shrpshtr325
THE ULTI-MOD
i believe that would work,
but keep in mind that the 2wd trucks did use shorter shocks in the back than the 4x4s (3/4 of an inch shorter according to napa) so they might not ride like you expect, im sure duranged or indy will have more info for you on this when they see the thread
Old Jun 6, 2010 | 03:53 PM
hydrashocker's Avatar
hydrashocker
Why not go for Bilstein shocks. You will not get any better towing capability with an adjustable shock, only a different ride is all?
Old Jun 6, 2010 | 05:21 PM
WhiteWidow00
Indeed, I'm not looking for any better towing capabilities. Just for when I'm pulling my 4000 pound trailer going thru the hills of Tennessee, get the best ride as possible.
Old Jun 6, 2010 | 05:59 PM
shrpshtr325
THE ULTI-MOD
4000 lbs should not have a huge effect on these trucks if you look at the tow capacities you are just over half way there with the 5.9
Old Jun 6, 2010 | 11:03 PM
hydrashocker
+ 1 Sharps!
Old Jun 6, 2010 | 11:14 PM
WhiteWidow00
I understand they have great towing capacity for their size, I just am in need of replacing the shock absorbers anyways, both front and back because they have a horrible bounce so was just looking for the best in everyone opinion.
Old Jun 24, 2010 | 10:11 PM
WhiteWidow00
Follow up: ended up puting Monroe shocks on it. Got the reflex for the front and the sensa trac weight adjusting spring loaded on the back and it rides perfect. Couldn't ask fr a better ride than I'm getting now. It's amazing how it rides better with weight on the tail too!
