Electric Fan Shroud
Yep, went down to Lowe's and picked up a small vise C-clamp the heads were small enough to get up in there and prevent the clip from turning. Had to do the same on the re-install since I couldn't get the clip out.
Well after all that...my air is still blowing lukewarm. It is hot outside, but I let it idle for about 15 mins now and it's no where near cooling the cabin off.
Fan is running great, so I'm not sure where to go from here. Compressor?
Again, it blows cold going down the road and everything is great. But, stop at red light or a drive-thru and it stops blowing cool.
Freon was the first thing I checked. Even swapped the A/C relay with another relay in the PDC.
Saw mention of checking the "A/C Compressor Clutch Relay" in the service manual, but I'm assuming that's the same relay I swapped around.
I don't see any other relays referring to "clutch" or "A/C" in the lid reference. Except for the 40 amp HEVAC FAN fuse and the 10 amp A/C fuse, which are both good.
I'm starting to wonder, if my clutch and/or compressor is bad. I noticed after I turned off the engine, I hear a high pitch sound coming from the compressor and the pulley for the clutch moves a little bit.
