A/C Help
Old Jun 21, 2010 | 09:22 PM
JET's Avatar
JET
Originally Posted by hydrashocker
Call Auto Zone. I know they sell the bearing so they should sell the clutch packs and bearing in a kit or separate. Also you can try NAPA.
Autozone is $80 for the bearing, Ebay is $29 shipped. Mine started growling too, so I am going to replace the bearing.
Old Jun 22, 2010 | 11:16 AM
hydrashocker's Avatar
hydrashocker
You can always go pull a clutch off a bone yard. Did ya call NAPA or Auto Zone?
Old Jun 22, 2010 | 04:00 PM
dmeray1's Avatar
dmeray1
I have a friend who is going to do it....I thought about the boneyard thing but they say you need a special tool to remove the clutch. Anyway, I will now have a spare compressor. Maybe I should sell it?
Old Jun 23, 2010 | 08:23 PM
Kensai's Avatar
Kensai
Replacing clutch bearings is a PITA. This was one of my first projects to learn when I was taking my A/C HVAC class back in high school. It was alot of fun from the learning experience. Did it several times myself not on the Durango tho. It was a couple hour job and you have to have a special tool to hold the clutch from moving when you are removing the bolt and also need a special puller to pull the clutch out without damaging the drive pulley.
I do not rate this job as a usual DIY project. LOTS of smaller parts and lock rings that needs to be in the right place. One screw up will cost ya more than a possible compressor.
Old Jun 28, 2010 | 01:07 AM
scorpiome70's Avatar
scorpiome70
Default Along these lines
Not to hi-jack a thread, but where can I find the a/c lines for an '03 4.7? Besides the dealership, I cant seem to find them anywhere.
Old Jun 28, 2010 | 05:03 PM
hydrashocker
Junk yard.
Old Jun 28, 2010 | 06:38 PM
scorpiome70
Default Duh!
Wow, I totally spaced that one. Thanks.
