stupid question on A/C
Old Jun 24, 2010 | 07:04 PM
crazy5269's Avatar
crazy5269
Default stupid question on A/C
Hi
I just picked up a 98 durango with the 5.9 and had to replace the A/c compressor but for the life of me i cant find the expansion valves front and rear a/C please help thank you is there a possibility that it has an orifice tube? and not an expansion valve
thank you
Old Jun 24, 2010 | 08:08 PM
dhvaughan's Avatar
dhvaughan
check rockauto and/or autozone website for replacement parts and see what's listed. my 01 doesn't have an expansion valve. the high pressure line goes directly into the firewall.
Old Jun 24, 2010 | 10:16 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
talk to 45autopete, he is A/C certified and will be able to tell you where to look.
afaik the A/C uses expansion valves
Old Jun 25, 2010 | 09:45 PM
45AutoPete's Avatar
45AutoPete
You have a Ram Truck and he is talking about a Durango, two totally different beasts. Yours probably does have an expansion valve but it is located on your evaporator core. The answer to the OP's question is, it is located on your passenger side by the firewall and you will have to unbolt the lines and then the valve. Make sure you use new gaskets. The rear is located on the evaporator, inside the vehicle, under the trim on the right rear. Hope that helps ya.
Old Jun 26, 2010 | 09:17 AM
tm985's Avatar
tm985
I have the same problem and need my expansion valves replaces as well. Let me know how it goes for you.
Old Jun 26, 2010 | 09:31 AM
crazy5269's Avatar
crazy5269
Thank you very much i'm gonna tackle this beast sometime today i'll let you know how cool it is LOL thank you again
Old Jun 26, 2010 | 08:27 PM
45AutoPete's Avatar
45AutoPete
You are welcome, have fun with the rear A/C!! They are a PITA!!
Old Jun 29, 2010 | 07:39 PM
kid289's Avatar
kid289
i just replaced mine in my 98. i think its only one. its on the back passenger firewall
Old Jun 29, 2010 | 09:00 PM
Fox Fader's Avatar
Fox Fader
Out of curiosity, where is this?
Old Jun 29, 2010 | 10:33 PM
shrpshtr325
THE ULTI-MOD
open the hood, and look all the way behind the engine, on the passenger side of the truck . . .
