Durango V6 No start No spark
Old Jun 23, 2010 | 07:54 AM
Rob Lenski's Avatar
Rob Lenski
Default Durango V6 No start No spark
Retired friend of mine has a 1999 Durango with a V6. He said it quit on the road. He got it back home and into his garage. I'm assuming it was towed home. It won't start.
He said that he replaced the wires, distributor cap, rotor, and coil. Still no start. That's where I came in.
I pulled one of the plug wires off and hooked a grounded plug up to it. Had him crank the engine. No spark. Same with the secondary lead going from the coil to the center terminal of the cap. I hooked my test light up to primary wires on the coil by backprobing. With key on, the light lights up when the test light is connected between either wire and ground. When cranking the light does not flash. Since the coil is not being switched on or off, I assumed either hall effect switch, module, or wiring between these components. I recommended that he ohm out his hall effect and if defective, replace it. He didn't have a DVOM, so he just bought a new hall effect. Still no start.
I also noticed yesterday that I didn't hear the fuel pump come on.
I don't usually work on Mopars, but would like to help this guy out without breaking the bank. Any suggestions on where to go next?
Thanks!
Rob
Old Jun 23, 2010 | 11:00 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
sounds to me like the coil isnt firing id look into that(new coil) im sure hydra, or indy will have more ideas for you too
Old Jun 23, 2010 | 11:05 AM
blong4life's Avatar
blong4life
Check all the fuses and relays.
Old Jun 24, 2010 | 12:29 AM
hydrashocker's Avatar
hydrashocker
First of all I can't understand and follow what you are even talking about. You use terminology that would twist the mind of Albert Einstein!
With that said, I would check the key switch and current to the fuel pump (not just the sound) and I would replace the Crank Shaft sensor.
Old Jun 24, 2010 | 10:49 PM
IndyDurango's Avatar
IndyDurango
A v-6 in a 99 eh? Hummmm.
IndyD
Old Jun 25, 2010 | 07:31 AM
shrpshtr325
THE ULTI-MOD
good eye indy, that does sound odd . . .
Old Jun 25, 2010 | 01:39 PM
hydrashocker
It was made in 1999 only!
It is a 3.9L V6 engine but they were not very popular so they discontinued.
Old Jun 26, 2010 | 01:36 AM
IndyDurango
Sure it wasn't 1998 only?
The only V-6 I have ever seen also had front row bench seating.
IndyD
Old Jun 26, 2010 | 10:28 AM
shrpshtr325
THE ULTI-MOD
i agree with indy, i thought 98 only . . .
Old Jun 26, 2010 | 11:36 PM
hydrashocker
No it was 1999. Here it states 1999-2000 but it wasn't in the 2000's: http://en.wikipedia.org/wiki/Dodge_Durango
Also here it is on the Government page: http://www.fueleconomy.gov/feg/bymake/Dodge1999.shtml
Don't know on the bench seat tho??????
