Loosing coolant cant find leak
Old Jul 1, 2010 | 09:12 AM
zebrim's Avatar
zebrim
What is the proper method to burp the 4.7 because i have been told a few different methods and cant find a thing on here for how to properly burp the 4.7 if some one could explain the proper method i would love to know.
Old Jul 1, 2010 | 09:55 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
o dannnn...... (he has the simplest explanation, and it is correct)
Old Jul 2, 2010 | 01:18 PM
hydrashocker's Avatar
hydrashocker
STANDARD PROCEDURE - REFILLING
COOLING SYSTEM 4.7L ENGINE
(1) Tighten the radiator draincock and the cylinder
block drain plug(s) (if removed).
CAUTION: Failure to purge air from the cooling system
can result in an overheating condition and
severe engine damage.
(2) Remove the cooling system bleed plug from the
radiator upper hose inlet housing. (Fig. 8)Fill system
using a 50/50 mixture of ethylene-glycol antifreeze
and low mineral content water, until coolant begains
coming out of the cooling system bleed hole. Install
the cooling system bleed plug. Fill radiator to top and
install radiator cap. Add sufficient coolant to the
reserve/overflow tank to raise level to FULL mark.
(3) With heater control unit in the HEAT position,
operate engine with radiator cap in place.
(4) After engine has reached normal operating
temperature, shut engine off and allow it to cool.
When engine is cooling down, coolant will be drawn
into the radiator from the reserve/overflow tank.
(5) Add coolant to reserve/overflow tank as necessary.
Only add coolant to the reserve/overflow
tank when the engine is cold. Coolant level in a
warm engine will be higher due to thermal
expansion. To purge the cooling system of all air,
this heat up/cool down cycle (adding coolant to cold
engine) must be performed three times. Add necessary
coolant to raise tank level to the FULL mark
after each cool down period.
STANDARD PROCEDURE - ADDING
ADDITIONAL COOLANT
The use of aluminum cylinder blocks, cylinder
heads and water pumps requires special corrosion
protection. Only Mopart Antifreeze/Coolant, 5
Year/100,000 Mile Formula (glycol base coolant with
corrosion inhibitors called HOAT, for Hybrid Organic
Additive Technology) is recommended. This coolant
offers the best engine cooling without corrosion when
mixed with 50% distilled water to obtain to obtain a
freeze point of -37°C (-35°F). If it loses color or
becomes contaminated, drain, flush, and replace with
fresh properly mixed coolant solution.
CAUTION: Do not use coolant additives that are
claimed to improve engine cooling.
STANDARD PROCEDURE—COOLANT LEVEL
CHECK
NOTE: Do not remove radiator cap for routine coolant
level inspections. The coolant level can be
checked at coolant recovery bottle
The coolant reserve/overflow system provides a
quick method for determining coolant level without
removing radiator pressure cap. With engine not running,
open the coolant recovery bottle cap and
remove coolant level indicator dipstick to observe
coolant level in coolant recovery bottle. The coolant
level should be between ADD and FULL marks. If
the coolant level is at or below the ADD mark, fill
the recovery bottle with a 50/50 mixture of antifreeze
and water ONE QUART AT A TIME. Repeat this procedure
until the coolant level is at the FULL mark.
Old Jul 2, 2010 | 02:46 PM
zebrim's Avatar
zebrim
This might be a really dumb question but if you are leaving the radiator cap as well at the bleed screw on how does the air get out of the system? ive always known that you needed to remove the radiator cap when burping the system. Also where exactly are the block drain plugs ive looked for a picture or somthing of them but can seem to find anything. thank all of you so much for all the help and ideas you have given me so far.
