Another A/C question
Old Jul 4, 2010 | 10:13 PM
BeachBoy's Avatar
BeachBoy
Default Another A/C question
Sorry if you guys are tired of talking about A/C, but couldn't quite find a good answer in other threads. What would be the first couple of things to look at if the A/C is kinda cold, but not where it should be. No, I haven't put a thermometer on the vents yet. The refrigerant pressure is fine. Compressor seem to be working normal. Thanks in advance
Old Jul 4, 2010 | 11:24 PM
45AutoPete's Avatar
45AutoPete
Read the A/C Sticky that they have posted here. You will need gauges to correctly read pressures and of course, the temp. out of your vents depends upon ambient outside temps. With the year of your Durango, I would not expect it to blow out as cold as it was new, compressors do have a tendency to get weak with age. Parts do wear out.
