2003 Durango Hub Assembly
Old Jul 6, 2010 | 03:10 PM
tg1051's Avatar
tg1051
Default 2003 Durango Hub Assembly
Sorry if this is posted wrong. I don't get into forums very often, but this one has helped in the past. I have replaced hub assembly in the past and grinding noise has gone away. It comes back after a few months. Need to replace again. Is this and alignment issue that continues to make it go out? Just seems there is a bigger issue than the hub assembly. Any input would be great.
Old Jul 6, 2010 | 03:26 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
i would raise the same question you have about the hub going out so fast.
but i must ask the stupid question DID you get it aligned after replacing the hub?
whenever you do front end work i recommend getting a 4 wheel alignment done on the truck just to be sure that everything is in spec.
also did you replace with new hub? and did you get the correct one (for 2 or 4 wheel abs)? how many times have you actually replaced the hub?
it almost seems like you may have gotten a defective hub to begin with.
btw the fav brand on here for hubs is timken id recommend them too (i used em)
Old Jul 6, 2010 | 05:43 PM
tg1051's Avatar
tg1051
Thanks for the response. Did not get it aligned, but was wondering about that. Got the hub from O'Reillys, so I believe it was new. Looks as if I will buy another hub, replace, and then get it aligned. Note to everyone. No stupid questions. I am a rookie and feel I may over look things that are obvious to others.
Old Jul 6, 2010 | 07:18 PM
shrpshtr325
THE ULTI-MOD
another thing which is more likely than the new hub being bad (if the replacement hub went bad again in months i would take it back and demand a refund) is that the hub on the OTHER SIDE of the truck has now gone bad and is causing the noise.
