Rear 12 volt plug-in
Old Jul 12, 2010 | 10:50 PM
ccckirch's Avatar
ccckirch
Default Rear 12 volt plug-in
Over the weekend I attempted to power a stereo by plugging into the rear 12 volt plug-in. This plug failed to provide power. The other two plugs up front work fine. Any of you fine folks know how to fix this problem? Thank You in advance!
Old Jul 12, 2010 | 10:54 PM
Trapstud's Avatar
Trapstud
I am thinking that there is a loose connection somewhere leading up the the rear plug. I know the fuse for all three is under the dash on the drivers side.
Old Jul 12, 2010 | 11:48 PM
SumAmerican's Avatar
SumAmerican
pretty sure that all the plugs are on the same fuse.. so Trapstud probably has it down
Old Jul 13, 2010 | 12:41 AM
hydrashocker's Avatar
hydrashocker
There might be one behind that fuse panel in the dash so look there as well and check the leads at the plug.
