Transfer case chatter!!!
Old Jul 13, 2010 | 01:02 AM
countryboy9078's Avatar
countryboy9078
Exclamation Transfer case chatter!!!
I have got a 2000 durango and just changed out the trans. The transfer case is starting to chatter. The rear seal went out and I changed it and re field it with fluid and still does it. I can put the transfer case in N and the trans in D and u can here the chatter or when you are driving down the road.When I put into 4 wheel drive its like its wanting to slip in and out.Can anyone help!!!!
Old Jul 13, 2010 | 07:34 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
sounds to me like the chain in your t-case has stretched out to the point that it is slipping
Old Jul 14, 2010 | 01:25 AM
hydrashocker's Avatar
hydrashocker
+1 bad or worn chain.
Old Jul 29, 2010 | 01:02 AM
venomouse's Avatar
venomouse
Originally Posted by countryboy9078
I have got a 2000 durango and just changed out the trans. The transfer cases is starting to chatter. The rear seal went out and I changed it and re field it with fluid and still does it. I can put the transfer case in N and the trans in D and u can here the chatter or when you are driving down the road.When I put into 4 wheel drive its like its wanting to slip in and out.Can anyone help!!!!
Why don't you try to replace your transfer case.
Old Jul 29, 2010 | 10:01 PM
hydrashocker
The 2000 was a change over year so there could be a lot of different T-cases in that model. Besides, if he rebuilds it he knows what he has. The last shop that rebuilt mine was like $750 installed.
Old Jul 30, 2010 | 01:35 AM
onseytote's Avatar
onseytote
transfer case
Seconded! it's the chain.
