High Idle on 4.7L
Old Jul 13, 2010 | 07:53 AM
Deep6's Avatar
Deep6
Default High Idle on 4.7L
I have an 03 4.7L Durango. The idle is around 1000 in park and about 800 in drive. How do I get it down. I tried removing the battery term. and reseting the computer but, it did not make a differance. Would it be the TPS?
Old Jul 13, 2010 | 02:28 PM
Fox Fader's Avatar
Fox Fader
Some say clean the IAC, some say replace it. Some say replace the TPS. Some even say replace the O2's. All say clean the throttle body. I wish you and me good luck.
Old Jul 13, 2010 | 06:31 PM
45AutoPete's Avatar
45AutoPete
Clean the throttle body and IAC.
Old Jul 13, 2010 | 08:42 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
+1 pete,
i would start by cleaning the tb and IAC, then replace the IAC if that wasnt enough.
Old Jul 14, 2010 | 12:57 AM
hydrashocker's Avatar
hydrashocker
+2 guys!
Old Jul 14, 2010 | 04:02 PM
Deep6's Avatar
Deep6
Thanks guys, if it ever stops raining I'll get out there and give it a try.
Old Jul 14, 2010 | 08:38 PM
Deep6's Avatar
Deep6
OK I cleaned the TB and IAC and now it idles higher 1300 in park and 900 in drive. uhh, so now what replace the IAC?
Old Jul 14, 2010 | 09:18 PM
45AutoPete's Avatar
45AutoPete
Sounds like you have a bad IAC. Looks like it is time to replace that.
Old Jul 14, 2010 | 10:51 PM
shrpshtr325
THE ULTI-MOD
yup, i would look at the IAC as the culprit, fortunately they are not expensive ($20 i believe last time i had to buy one, might be a little more now)
Old Jul 15, 2010 | 10:27 PM
MAGIC84's Avatar
MAGIC84
Sharp, you must have broujght a IAC quite a while ago....O reilly Advance/AutoZone show $76.99 for IAC valve........Where did you get yours?
