98 durango ac problem
I was able to ground the problem wire from the relay box (well 99 percent) of it is grounded,but the clutch still won't engage. Dia. now points to PCM and that probably means wire harness too. Thank God for windows and 60MPH- ZEEKESTER
Thanx Hydrashocker I just hate paying shops to work on tec. problems, I think they loose track of time,and my money. The only thing I have going for me, is I remember when I installed 480 Comp. roller cam this occured.
I like new roller cams.......LOL
First lets figure out what the issue is:
Unplug the solenoid.
Hook a hot wire to the hot and ground the negative end while the engine is running and see if it engauges. If it does the problem is elsewhere. If it still does NOT engauge then it's the solenoid on the A/C clutch.
ummm, i think you mean if this causes it to engage then the solenoid IS the problem . . . (drink much tonight
My high pressure cut off switch, is reading voltage on both sides. My book doesn't show the solenoid is it at the bottom of the compressor, can you direct me? I like my Comp. Roller too,Hydrashooker Thanks. Has 1.7 roller rockers too, MOPAR PERFORMANCE kit. I really like your High Boy, I'd like to look under the hood of that BEAST. Try 26MPG with a Cortex(is my face red)and other gooodies.
zeekester
I did jump the low presser cut off switch, by the fire wall,shoot no good,and probed the wires to get the clutch to engage and it run, and grounded the ground side of that HPCOS, shucks no good again. I need to get a gun, and not a BFH-right? LOL
zeekesterI did jump the low presser cut off switch, by the fire wall,shoot no good,and probed the wires to get the clutch to engage and it run, and grounded the ground side of that HPCOS, shucks no good again. I need to get a gun, and not a BFH-right? LOL
zeekester
I don't think you understand. To make a circut you have power go into the hot side and ground the other side. If the solenoid clicks on the magnet powers clenching the clutch plates and the compressor would engage and run. If now the clutch would not engage it would just spin on the bearings.
Ive noticed today that my a/c compressor is not spinning is there anything else i can do to fix it without replacing it completly? It will turn by hand it just wont engage, also it looks to be grounded on the compressor itself on the back right side...looks kinda iffy to me but Im no expert. Also it blew a shot of cold air for the first time after i secured some wires back into the terminal on the - side but only lasted a second now theres a kinda sloshing sound every few seconds which gets louder with the blower
