Crap, It's Broken...
Old Jul 26, 2010 | 04:29 PM
Tronix's Avatar
Tronix
Unhappy Crap, It's Broken...
I have a 2002 Dodge Durango. And, it has recently started over heating. But, Not while moving only while it's idle. Any suggestions? The heating issue slows down a little when the A/C is turned off. But, there isn't much of a difference between it being on and off.
Thank You,
-Tronix
Old Jul 26, 2010 | 08:25 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
one of your fans isnt working properly, make sure that the electric fan is starting up when the A/C goes on and spin the clutch fan by hand (with the engine off) and see how far it turns, there SHOULD be some resistance there, less than 1/2 a turn is what you are looking for.
Old Jul 26, 2010 | 08:47 PM
1999_Durango_SLT's Avatar
1999_Durango_SLT
Could be a plugged coolent system too no?
Old Jul 26, 2010 | 10:09 PM
shrpshtr325
THE ULTI-MOD
its possible, but highly unlikely since it is cooling just fine when the truck is moving, that tells me that the coolant is flowing through the radiator and is being cooled off by air movement when the truck is moving, however when he stops moving, so does the air (idk anyone who idles while driving) which means that his fans are not moving enough air over the radiator
Old Jul 27, 2010 | 12:01 AM
IndyDurango's Avatar
IndyDurango
Is it a 4.7l?
(burp)
IndyD
Old Jul 27, 2010 | 12:37 AM
Tronix's Avatar
Tronix
Yes its a 4.7 the clutch fan turns about 2 times with a light pull. Can't tell right now about the electric fan will check that in the morning.
Thank you
Old Jul 27, 2010 | 01:08 AM
IndyDurango
I thought so.
Assuming you have a factory stat...Run fresh fluids and properly burp the system. If there are no hardware problems, that should/will take care of it.
IndyDurango
Old Jul 27, 2010 | 07:31 AM
shrpshtr325
THE ULTI-MOD
Thank you
doesnt this scream bad clutch fan at you indy? if it turns around twice when spun by hand? (not saying it doesnt need more, but this seems like an easier starting point)
Old Jul 27, 2010 | 01:11 PM
1999_Durango_SLT
I was thinking the same but thought it may be different for the 4.7L?
Old Jul 27, 2010 | 01:25 PM
shrpshtr325
THE ULTI-MOD
nope, cluth fan is a clutch fan afaik (different in make, but similar in function mine spins less than one fan blade) and i have a 4.7
