Automatic To Manual Trans swap.
Old Aug 9, 2010 | 04:11 PM
Matt Marshall's Avatar
Matt Marshall
Default Automatic To Manual Trans swap.
I've got a 98 5.9 slt. Great truck, but I'd like to throw a manual trans in er.
As far as I know, I can get a manual trans from a 96 and up.
I figure I can get a used transmission and transfer case, just note sure which parts I should just go new?
Starting this next week, so need to know asap. Will post some pics after as well.
Old Aug 9, 2010 | 04:25 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
i have similar plans for mine at some point way down the road, it should work, i would use parts from a dakota of the same year if possible (find one with a 5.2 and a manual trans if possible), and you will probably need (do not quote me on this, but it is what i would get, well id buy a wreck with the trans in it so id have all the parts i needed)
1. transmission (duh)
2. t-case (prossibly)
3. driveshaft (again, only if you change the t-case)
4. hydraulic clutch assembly
5. clutch master cylinder
6. any interior trim pieces to hide the new hole you will be putting in the floorboard
like i said, i would buy a wreck which is still intact for the parts and take what i needed used, and replace some with new as i went along.
btw, they did not make the durango before 98
Old Aug 10, 2010 | 01:18 AM
IndyDurango's Avatar
IndyDurango
No D has had a factory stick. I would look for one from a Dak if you plan on a swap and it MAY work.
IndyD
