Durango ride height....
Old Aug 11, 2010 | 11:07 PM
siw1978's Avatar
siw1978
Default Durango ride height....
Hi,
I am new to this forum and have been reading the theads on the ride height of peoples Durangos- I am a bit confused....
I have 2002 Durango R/T. I love the thing but the ride height at the rear is about an inch or so lower than the front and quite noticeable if you look closely enough.... It is really beginning to grate on me....
I have read about the torsion bars and T/S lifts and think it to be a it beyond me.... Is there a simple way to raise the rear of my truck to level it out ??
Thanks in advance.....
Si
Old Aug 12, 2010 | 12:07 AM
master tech's Avatar
master tech
Site Moderator & Tech
HEIGHT MEASUREMENT
The vehicle suspension height MUST be measured and adjusted before performing wheel alignment procedure. Also when front suspension components have been replaced. This measure must be performed with the vehicle supporting it's own weight and taken on both sides of the vehicle.
NOTE: Vehicle should have a full tank of fuel prior to measuring and adjusting alignment.
FRONT CURB HEIGHT MEASUREMENT
1. Inspect tires and set to correct pressure.
2. Jounce the front of the vehicle.
3. With vehicle on level ground or hoist, make the following measurements: a. Front wheel spindle (center) (1) to ground vertical distance (3).
b. Center of the front face of bolt on the rear leg of Lower control arm (2) to ground vertical distance (3).
c. Difference between spindle and control arm bolt to ground distances should be 81 mm +/- 3.2 mm (3.18 in +/- 0.12 in)Note that the control arm bolt is lower than the spindle.
4. If adjustment is required, turn the torsion bar adjuster bolts- if lowering curb height, unscrew Torsion bar adjuster bolt beyond desired point so as to set height when screwing-in adjuster bolt.
5. After making any curb height adjustment, roll vehicle preferably jouncing it also, to relieve camber Effects and then re-measure Lower control arm bolt to ground height.
6. Repeat the previous steps until the curb height is within specifications.
REAR CURB HEIGHT MEASUREMENT
3. With vehicle on level ground or hoist, make the following measurements: a. Distance from the landing pad of the jounce bumper on the axle side to the jounce bumper cup lip of the frame side.
b. The difference between the jounce bumper landing pad and the jounce bumper cup lip. The reading should be 148 mm +/-10 mm (5.8 in +/- 0.40 in) for 9.25" axle, 154 mm +/-10 mm (6.0 in +/- 0.40 in) for 8.25" axle.
Old Aug 12, 2010 | 09:20 AM
Dans01Durango's Avatar
Dans01Durango
Yeah, what MT ^^ said!
Old Aug 12, 2010 | 01:09 PM
siw1978's Avatar
siw1978
Thank for the reply ......
So, there is no bolt on the rear to just raise it like there is on the front?
I think I got most of the first reply!
